WTS: ISC Adjustables (latest in town)
kayang
ISC ADJUSTABLE ABSORBERS
This top of the range product dominates its competition by having an amazing 32 steps of damper adjust ability, bound adjustment, height adjustment and on various models camber adjustment. Camber on some models can also be adjusted via the lower bracket with our larger bolt hole design.
All of our coilovers come with 12 months warranty.
The coilover can be lowered approx 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for drift/rally/drag and of course street.
32 Step Damper Adjustable
  • Precise control damp valve
  • Operates smoothly on all road surfaces
  • Expansion/Suppression of shock adjustment
Pillowball Uppermount (OPTIONAL)
  • Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
  • High rigidity steel piston rods
  • Meets with race/sport standards
Sports Spring
  • Made from high quality SAE9254 steel
  • Tested over 500,000 times on compression inspection with less than 5% deformation.
Ride Height Adjustable
  • Full length height adjustable
  • Bound adjustable with separate spring locks
  • High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium Bracket
  • Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
  • Specifically anodised surface to prevent inside corrosion and surface rust
  • On various models camber can also be adjusted via the bracket aswell as the camber tops
Single Cylinder Design
  • Larger cylinder and piston design to advance driving stability and dexterity
Available for BMW, Citroen, Honda, Lexus, Mitsubishi, Toyota, Nissan, Ford, Mazda, Proton, Peugeot, Subaru, Suzuki, Hyundai and Volkswagen.
Please call me up for further information.Thanks!!
0162659889 Jason
pm me the price for nissan s14. tq
Bro, pm me the best price for ae92. Thanks !!
wah~~~~like that u can earn alot from every1 here...hehehe...wish u good luck in ur biz ya...
Honda civic 96-98 4door pm me best price. thanx
Integra DC2 please.
