hello..i want to ask sumthin..hope u guys can help..i have 4g93 engine but the wiring still using 1.6 wiring..did i need to change the whole wiring or only the computer box?pleaseeee
you can do it even for a 4g93 twincam, just that you need a 4g91 carb distributor since you won't be able to use a 4g93's crank angle sensor... a 4g91 carb distributor is pnp to the 1.6's wiring. did this conversion sometime ago.... i would really suggest using back the original 4g93 wiring.
Hi guys. I would like to share my experience building a voltage stabilizer for my old Civic. The purpose of this device, as with all automotive voltage stabilizers, is to reduce electrical noise and distortions...
I'm driving waja for 8 yrs and there is some noise coming out from top right corner. I'm suspecting worn ball joint, suspension bush or strut top mounting.
