Main Forums
Interests
ICE
What is minimum amp(watt) should i use?
<blockquote data-quote="takumi86" data-source="post: 856436" data-attributes="member: 7322"><p>my frien told me that some amp got the cut off to prevent over heat.</p><p>soo need add on PC fan or something to reduce the heat..</p><p>eg: in 4 hours driving, u can listen music wiz the amp on around 1 hour..</p><p>then need to turn off engine to activate the amp back....</p><p>any comment on this!??!.. ;)</p></blockquote><p></p>
[QUOTE="takumi86, post: 856436, member: 7322"] my frien told me that some amp got the cut off to prevent over heat. soo need add on PC fan or something to reduce the heat.. eg: in 4 hours driving, u can listen music wiz the amp on around 1 hour.. then need to turn off engine to activate the amp back.... any comment on this!??!.. ;) [/QUOTE]
First drive: 2017 AMG GLA 45 375hp Monster Hatch
Entering the jacked up AMG, I am immediately greeted by its noticeably higher seating position, almost in between that of a car and a real life SUV. This is not the sort of hot hatch I was expecting...
Selamat berpuasa - 2011/1432h
As'salam to all muslim friends.
Wishing you all "SELAMAT BERPUASA - 2011/1432H"
But never "puasa" modding your ride...
Need Advice for Adjustable Cam Pulley (DOHC Engine)
to all pro zth member
usually u all Set how much Cam pulley timing for adjustable Cam Pulley (DOHC) Engine ..?
how much Degree u all advance ?
Intake ..?
Exhaust ..?
need sincere advice for GSR and EVO Engine
tq ^^
Main Forums
Interests
ICE
