Main Forums
Car Talk
Forced Induction & Engine Management
vr4 220hp ecu
<blockquote data-quote="bujang_hensem" data-source="post: 234058" data-attributes="member: 1807"><p>i think it can be done..but need to change wiring from pin 14 and 7 i think....mean twist the wire lor..but some car will get check light....better not to do it lor...accually vr4 200 hp the ecu more tahan maa....because the capasitor got 12...compare to 220hp only got 3 only and if sampai masa it will leak....</p></blockquote><p></p>
[QUOTE="bujang_hensem, post: 234058, member: 1807"] i think it can be done..but need to change wiring from pin 14 and 7 i think....mean twist the wire lor..but some car will get check light....better not to do it lor...accually vr4 200 hp the ecu more tahan maa....because the capasitor got 12...compare to 220hp only got 3 only and if sampai masa it will leak.... [/QUOTE]
ATR Gear slip
Hi,
My Trekker have this problem where the gear slips when it's hot.
I changed the ATF with treatment fluid. And a check on the ECU shows an error P0170 - fuel trim bank 1. Vacuum leaks?
My wife use the Trekker...
Change Exhaust
Sorry newbies here...
I want to put a straight through exhaust.. But now market doesnt have exact fit for airtrek..
So planning to buy a 2nd hand 1..
But saw the original extractor pipe 'U' shape....
How ar ?
how to diy black head lamp for wira??
any cfus??? want 2 save budget hehehe.....can any 1 teach me how 2 diy black for stock wira headlamp???
Main Forums
Car Talk
vr4 220hp ecu
