SoundBlok soundproofing - best for DIY
ICE -In Car Entertainment
cutypuppy
Malaysia
Hi Guy, as the subject, I'm selling the product as below. To Whom are interested, kindly PM me. For whom don't like to DIY, i can do the installation, kindly PM me for the quote.
1-Supression Pad :-
10pcs - RM 40.00
20pcs - RM 80.00
Spec:-
Specification:
Thickness ........................... 3mm (0.12 inches)
Size .................................... 9cm x 18cm (3.5 inch x 7.1 inch)
Color .................................. Black.
Weight ................................ 3 kg/M2 (0.61 lb/ft2)
62g (2.2 oz) per pad
Water absorption ................. Softening Point ................... 155°C.
Tear Strength ...................... 400N
Tensile Strength @ 23°C ..... 14KN/m
Adhesive Type ..................... Solvent Acrylic 90 gsm
Adhesive Temperature ......... 150°C max. resistance @ 15min
Adhesion to Steel ................ 1.1kg/25mm
Kindly refer to below for the photo
Product:-
Location to install:-
2-Flex Mat:-
1 roll (20cm x 122cm) - RM 45.00
Specification:
Thickness ........................... 2.1mm
Color .................................. Top – Heat reflective aluminum.
Underside - Black.
Chemical resistance ............ Resistant to oil, diluted
acids and alkalis.
Weight ................................ 3.1 kg/M2
Water absorption ................. Melting Point ....................... 150°C.
Material is fire retardant.
Operational Temperature ..... -30°C to 80°C.
Storage Life ........................ Indefinite
Product:-
Location To Install:-
For others product, kindly refer to the link below
http://www.soundblok.g0ldeneye.com/
Bro, pm me ur location. how much needed for a wira aeroback?
bro pm me the price for iswara aeroback for sound proofing the whole body...
Hi marleyz, reply your PM, kindly check your mailbox ;)
Bro pm me the price for Savvy for sound proofing the All 4 door & all 4 wheel house ...
1 question... after install it, will it inprove the Audio Quality...?
cus my speaker make my door/door panel shaking went i increase the volume...?
bro pm me the price for Proton Saga (old) for sound proofing...
only for 4 doors and boot...and if i do not know how to install could you done it?
pm me the best price supression pad for Myvi + installation ya...Thanks!!
bro, pm me for 4 doors, wheel arch sound proofing for civic eg 4 door
Interested in your Flexmat. How much is needed for firewall and wheel arch? Please quote including installation. Thanks.
Hi cyfer, the dimension of the flexmat/ roll is 20cm x 122cm, Anyway, i'm not sure how big is your car & how u want to be done, so you have to estimate it.
Installed User
Any user that has intalled this product?
What is the effect? Any obvious dampening difference before and after installation?
bro,
i want Supression Pad and Flex Mat. pm me ur location. how much needed for a wira aeroback + installation u did.
Thanks
