Main Forums
General Talk
Something Is Wrong With My Os
<blockquote data-quote="TRD16v" data-source="post: 500590" data-attributes="member: 2009"><p>lozo,</p><p>use the vcleaner.exe which i've ask u to download from grisoft.com website and then boot up ur system to safe mode and run it to clean.</p><p></p><p>Now, the real situation here is the program for sure cannot be found in the C drive as it has resides in your registry. Try to remember back the path setting where the virus program you have accidentally installed it. Once u've found it do the steps below:-</p><p></p><p>(1) Click Run and type REGEDIT and press ENTER.</p><p>(2) Click at "Hkey_Local_Machine"</p><p>(3) Double click at "Software"</p><p>(4) Double click at "Microsoft"</p><p>(5) Double click at "Windows"</p><p>(6) Search around this area for such program. If not found skip and proceed step 7</p><p>(7) Double click at "CurrentVersions" and look for Run, RunOnce, RunOnceEx, RunServices or RunServicesOnce. Look for all possibilities in this section as the program might reside here so whenever ur windows loads up it will also follow suit.</p><p></p><p></p><p>If the above don't work, then look into the services (User running on Win2k, Win2k3 or XP home/pro). To go into this, click at Start button, Run and type services.msc and press enter. You will come to a screen where all services are running. Look for the program or any funny name and stop the services and then follow by disabling it.</p><p></p><p></p><p>If still don't work, go to Start button, click at Run and type "msconfig" and press enter. Look at "startup" section and see whether that virus program are selected or not on the check box. If yes, uncheck it, save it and then restart ur system. Lastly restart ur pc in safe mode and use any available anti virus that u have inside ur system to run a full cleaning.</p><p></p><p></p><p></p><p></p><p></p><p>Regards,</p><p>Mike</p></blockquote><p></p>
[QUOTE="TRD16v, post: 500590, member: 2009"] lozo, use the vcleaner.exe which i've ask u to download from grisoft.com website and then boot up ur system to safe mode and run it to clean. Now, the real situation here is the program for sure cannot be found in the C drive as it has resides in your registry. Try to remember back the path setting where the virus program you have accidentally installed it. Once u've found it do the steps below:- (1) Click Run and type REGEDIT and press ENTER. (2) Click at "Hkey_Local_Machine" (3) Double click at "Software" (4) Double click at "Microsoft" (5) Double click at "Windows" (6) Search around this area for such program. If not found skip and proceed step 7 (7) Double click at "CurrentVersions" and look for Run, RunOnce, RunOnceEx, RunServices or RunServicesOnce. Look for all possibilities in this section as the program might reside here so whenever ur windows loads up it will also follow suit. If the above don't work, then look into the services (User running on Win2k, Win2k3 or XP home/pro). To go into this, click at Start button, Run and type services.msc and press enter. You will come to a screen where all services are running. Look for the program or any funny name and stop the services and then follow by disabling it. If still don't work, go to Start button, click at Run and type "msconfig" and press enter. Look at "startup" section and see whether that virus program are selected or not on the check box. If yes, uncheck it, save it and then restart ur system. Lastly restart ur pc in safe mode and use any available anti virus that u have inside ur system to run a full cleaning. Regards, Mike [/QUOTE]
Track Day on 17th October 2013 - Limited Cars
Hello All,
There's a track day on the 17th October 2013 (THURSDAY) at Sepang International Circuit (SIC). Visit: http://www.fastmotorsport.my
Total duration: 4 hours from 10am - 2pm (Limited to 60 cars)
Early...
Need help
Bro, is that normal if oil come out from oil catch tank breathe hole? This happen only during dyno run and rev above 7k.
remap ecu
guys..im wondering..can i remap gen 2 ecu n make it more fuel-saving(u know la fuel price these days.ish)? if can,where to?
Main Forums
General Talk
