Soft 99 Fusso Coat 12 Months Wax
Yikseetoh
Soft99 Fusso Coat 12th Wax Long-term Anti-corrosion PTFE Waterproof Solid Wax
attachment.php
attachment.php
attachment.php
• Protection against scratches with strong water-repellent effect and strong covering for up to 12 months protection.
• After use if the car gets wet or dirty, all you need to is simply wipe a damp towel, and the car will begin to shine again.
• Prevents ageing of the painted surface
• Reduces the harm done byacid rain to a paint and varnish covering.
• Does not pass ultra-violet beams which can be the bottom layers of paint if the colour of the car has been changed.
Fusso Coat contains fluorine, it does not allow dirt and water traces to remain on the surface, water and dirt just wash away.
After application the care of the car becomes very simple just by washing the car with clean water, drying and rebuffing with a soft polishing micro fibre cloth.
Your car will be reliably protected from aggressive factors of environment for up to 12 months depending on weather conditions.
One pot of Soft99 Fusso 12 Month Coat Wax is enough to polish 4 cars(sedan B, C class).
Method of application:
• Wash your car with a good quality car shampoo and ideally a micro fibre wash mitt. Rinse with clean water and use a good quality drying towel making sure car is dry before using the wax. Degrease the surface of the car.
• Please do not apply the wax in direct sunlight or in dusty conditions as you could scratch the bodywork.
• After drying the car, apply the wax with the sponge provided and apply a thin even coat on the panel in a circular motion without applying too much pressure.
• Let the wax dry to a haze for no more than 5 minutes in the Summer and 10-15 min in the winter.
• Buff the panel clean with a soft micro fibre polishing cloth using forward and backward strokes. This should be very easy to do without applying too much pressure on the cloth.
• When the car becomes dirty over time, wash car as before using use a micro fibre wash mittt and a good quality car shampoo. Again use a micro fibre polishing cloth as before but on its own and the shine will be restored.
Attention:
After using the wax on a car, for best results please try and not drive the car for 7-8 hours.
If conditions allow and for best results, please do not wash the car with shampoo for a week, only use water.
Full polymerization of a polish makes 7 days.
Contact me at 0167227181
