Main Forums
General Talk
questions regarding those engine kosong
<blockquote data-quote="raja_emeperor" data-source="post: 1768834" data-attributes="member: 28272"><p>if u bought engine kosong,u still can register with jpj.but u must get the surat kastam.my car engine also i got from engin kosong/engine lantai.i dont need halfcut bcos i want to change the parts,i like rojak2 ie bigger turbine,bigger throttle body,bigger downpipe,and...ahahaha!!!! secret la.but actually it will cost alot more than getting the half cut.but if u want to heavily modded your engine and got more money,go and get engine kosong.</p><p></p><p>p/s:my engine also come from engine lantai.still i can manage to reg with the jpj.you just need kastam ltt.</p></blockquote><p></p>
[QUOTE="raja_emeperor, post: 1768834, member: 28272"] if u bought engine kosong,u still can register with jpj.but u must get the surat kastam.my car engine also i got from engin kosong/engine lantai.i dont need halfcut bcos i want to change the parts,i like rojak2 ie bigger turbine,bigger throttle body,bigger downpipe,and...ahahaha!!!! secret la.but actually it will cost alot more than getting the half cut.but if u want to heavily modded your engine and got more money,go and get engine kosong. p/s:my engine also come from engine lantai.still i can manage to reg with the jpj.you just need kastam ltt. [/QUOTE]
4g63t missfire.. help!!
hi all.... now i still troubleshooting my missfiring prob....
on idle = smooth
accelerate = smooth
boosting = smooth
misfire only at above 4000rpm while part throttle or maintain rpm... it happen at all gear...
revvin from 3k onwards felt heavy
im runnin on rb25det, everytime i rev past 3k rev, i felt da car is sluggish, n felt like combustion is stuffed...
any idea? wat plugs i shud use for stock engine stock boost stock setup?
when i take a corner...
b16a change b16b cam and valve spring with retainer problem
permalink
Need Help. currently my civic b16a change b16b cam and valve spring retainer problem.
Problem is when start car. need to press fuel for not...
Main Forums
General Talk
