hey guys which is better if wnna wack 2 double 12 inches dual voice coil MTX ..which amp is more powerfull... now i'm using DG-800 tot of upgradeing another sub so amp not kau enuff...will the F1-600 be suficient?? thx
DG-800 confirm can set at 1ohm...........F1-600 cannot set at 1ohm................
If u are not sure for the wiring to set at 1ohm......come see me, i will help u......
about choosing 1 from both dg-800 and F1-600, I will go for DG-800 if i am planning to use the amp weck woofer, and F1-600, if i am goin to use the amp for comp set or 3way speakers...........
if its dvc 4 ohm sub, wiring 2 units in parallel/parallel connection will give it a 1ohm load.
http://mobile.jlaudio.com/graphics/Support/Tutorials/wiring_images/DVC_Parallel_2.gif
dg800 no need to birdge the amp..it only got 1 chnnel..just connect all the positive from sub to positive on amp and negative on sub to negative on amp..then it will be 1 ohm..(if ur sub is 2x dvc 4ohm)
What about monoblocks that have `like a 2 channel out connection' similar speaker wire connection output like a conventional 2 channel amp? How do u wire that up with the same case scenario as above? Paralell?
hi those expert....if my sub is alpine 15" double voice coin (1pc only) its support 1 and 4 ohm....750rms ratting for the sub..so if buy this prokick F1-600 izzit can support ??
F1-600 cant fully drive Prokick 12" Single coil (model 2000-2005), dun think can this amp can drive DVC...but F1-600 can drive powerful few pair of mid bass for loud sound (SPL demo car).
For woofer, DG 800 is suitable model, and if possible get DG1200/1500 better...
Oh..but the owner say can drive 4pc woofer wo..js know ZTH have a guy put the prokick F1-600 info..he wrote 4ohm is 600 Rms (2channel) if mono can till 900RMS ..izzit true? I'm using the MA audio js 300rms for 4ohm then too weak to carry my sub..so my sub is 750rms so if 600rms still better..but bro,can u tell me the real info about this amp..I need to know :( thank man..
---------- Post added at 10:50 PM ---------- 6 hour anti-bump limit - Previous post was at 10:40 PM ----------
Izzit F1-600 is monoblock or 2channel or 4 channel ?really hope some1 can provide info..about this amp rms ratting with ohm..:)
F1-600 is 2 channel amp.
I not sure why it quoted at 600Watts but cant really drive eve Prokick Singe Coil especailly for customize enclosure (1.1ft), experienced with this amp before (past 6-7 years), and felt F1-400 better even smaller than f1-600,but dont think that f1-400 can fully drive DVC too... What I mean is when u open out your car boot and blast it in open air anyway..
4 pcs woofer can drive but is it can support the woofer at optimum level????:hmmmm:
DG800/1200/1500 (previous batch) is good amp for SPL lover, u also can try Agako amp as alternative anyway.
I'm thinking to buy a S15 and going to have a look 1 unit in Cheras this Saturday. Seller put a price tag of 110k and it is yr 2002(unreg).btw its a turbo spec. Can anyone of you here give me some tips...
There's been a few thread discussing tyres opinion, price and experience. Why not we compile this in one thread so is easy for everyone and visitor/newcomer to our forum to...
