Main Forums
Car Talk
Car Modification
No Cat vs Hi- flow Cat vs Muffler
<blockquote data-quote="clanbuster" data-source="post: 3861069" data-attributes="member: 77719"><p>I have been changing setup here and there due to some mod on engine.</p><p></p><p>Currently 1.5CC engine with 0.6 bar and abt 140 BHP.</p><p></p><p>I had tried remove Cat, then my low end speed is really like snail. Even stock 1.0CC car also can faster then me.</p><p></p><p>I put back the Cat and is fine, but from 120Km/h to 180 now is just abit faster then NA car.</p><p>Before put back the cat, is very very very fast climb up to 180 km/h</p><p></p><p>Now what should i do?</p><p></p><p>Change to Hi -flow Cat?</p><p>Change muffler with stock Cat?</p><p>Change whole piping to slightly bigger diameter with stock CAT and Muffer?</p><p></p><p></p><p>is there any equipment that detect the back pressure is too much or less?</p></blockquote><p></p>
[QUOTE="clanbuster, post: 3861069, member: 77719"] I have been changing setup here and there due to some mod on engine. Currently 1.5CC engine with 0.6 bar and abt 140 BHP. I had tried remove Cat, then my low end speed is really like snail. Even stock 1.0CC car also can faster then me. I put back the Cat and is fine, but from 120Km/h to 180 now is just abit faster then NA car. Before put back the cat, is very very very fast climb up to 180 km/h Now what should i do? Change to Hi -flow Cat? Change muffler with stock Cat? Change whole piping to slightly bigger diameter with stock CAT and Muffer? is there any equipment that detect the back pressure is too much or less? [/QUOTE]
david tao
S AFC2 need advise on adjustment
Sifu,
can anyone help me on my setting on 6a12tt. does the setting correct or need to do some adjustment?
Pit Equipments
Does any one know what is the Pole or Stand that holds the banner /board of "sponsors and team name" inside the pit called?? its something like a background.. a truss system?
Brunei Skylines~
I comes across wth ths videoclip. 2 R33 GTS-t ... launch control?Line locks?....
:_: awesome......
Main Forums
Car Talk
Car Modification
