Main Forums
General Talk
K&N Air Filter
<blockquote data-quote="2pac" data-source="post: 348879" data-attributes="member: 3635"><p>ok i went to N1 Racing.. the K&N filter 6" is RM260 adapter (steel) RM80</p><p>K&N 4" RM230</p><p>Blitz - 6" - RM380</p><p></p><p>Kakimotor - K&N 6" RM299 </p><p>K&N 4" 320</p><p>both without adapter.</p><p></p><p>I have another question - for Putra Standard Engine.. which is the best size 6" or 4". Will I loose power if I fix too big (6")...</p></blockquote><p></p>
[QUOTE="2pac, post: 348879, member: 3635"] ok i went to N1 Racing.. the K&N filter 6" is RM260 adapter (steel) RM80 K&N 4" RM230 Blitz - 6" - RM380 Kakimotor - K&N 6" RM299 K&N 4" 320 both without adapter. I have another question - for Putra Standard Engine.. which is the best size 6" or 4". Will I loose power if I fix too big (6")... [/QUOTE]
Auto Gearbox oil pan gasket leak
hi all..
i browse thru the
http://www.toyodiy.com/parts/p_J_2001_TOYOTA_ALTEZZA_SXE10-AEAVF_3503.html
but didnt found any part number for the oil pan gasket. mine worn out and the oil leak whenever i...
Pivot Engine Start Button
Wei, anyone had experience installing this button? easy or not?
claming ferrites on ignition cable
bought 4 ferrites for rm38 n clamp it on my ignition cable, the difference is very notice-able, reving bcome much easier n the pedal feel tighter! compare to changing ignition cable, tis 1 is more worth it! putingon...
Main Forums
General Talk
K&N Air Filter
