Car Brands
Car Manufacturers
Toyota
Jerk @ Ecu
<blockquote data-quote="kennix" data-source="post: 2513838" data-attributes="member: 1849"><p>Hi All,</p><p></p><p>I've been thru this problem mentioned too. I still haven't got a solution to it. The Mech said to change the Throttle body that he suspect is the throttle body sensor. I haven't changed the throttle body yet.</p><p></p><p>I'm having BLT in my car and the car will jerk only if I maintain in the RPM range of 2k-4k. The car will choke and jerk after a while driving, it goes normal then it will jerk again. </p><p></p><p>I've changed spark plugs, plugs cables. I have even added FPR which i suspect not enough fuel in the beginning. And still i'm searching for solution. Trying my luck here.</p><p></p><p>cheers.</p></blockquote><p></p>
[QUOTE="kennix, post: 2513838, member: 1849"] Hi All, I've been thru this problem mentioned too. I still haven't got a solution to it. The Mech said to change the Throttle body that he suspect is the throttle body sensor. I haven't changed the throttle body yet. I'm having BLT in my car and the car will jerk only if I maintain in the RPM range of 2k-4k. The car will choke and jerk after a while driving, it goes normal then it will jerk again. I've changed spark plugs, plugs cables. I have even added FPR which i suspect not enough fuel in the beginning. And still i'm searching for solution. Trying my luck here. cheers. [/QUOTE]
Vettel takes Infiniti's finest for a spin in Shanghai w/video
http://www.zerotohundred.com/?attachment_id=20064
The Shanghai Grand Prix may have ended on a sour note for the Red Bull Racing team as the wrong pit strategy let them down and allowed McLaren to snatch a win but...
Pirelli in the lead to supply F1 teams for 2011
https://www.zerotohundred.com/wp-content/uploads/2010/05/pirelliracingslick.jpg
Formula One's Technical Working Group met recently to discuss about F1's tyre supplier for 2011 but from what we know, no decision was...
Anti Lag Function
I know that some Ecu's such as motec and other advance ECU's have this function to reduce turbo lag when shifting and launching..how does it work..
Car Brands
Car Manufacturers
Toyota
Jerk @ Ecu
