Main Forums
Interests
ICE
Installing amplifier and subwoofer
<blockquote data-quote="renxun" data-source="post: 2438805" data-attributes="member: 33177"><p>if your batery was already relocated to the car rear boot then things wil be heck easy... the - terminal can direct ground to the batery terminal. however. when installing high power amps with large cables example big monoblocks make sure you remove your batery negative terminal first b4 you install anything... then after getting all the wire intact to the amp then only install batery terminal... had a very bad experience and expensive lesson for this.. smoked my monoblock once due to short circuit at the amp's - terminal when installing the ground cable.</p></blockquote><p></p>
[QUOTE="renxun, post: 2438805, member: 33177"] if your batery was already relocated to the car rear boot then things wil be heck easy... the - terminal can direct ground to the batery terminal. however. when installing high power amps with large cables example big monoblocks make sure you remove your batery negative terminal first b4 you install anything... then after getting all the wire intact to the amp then only install batery terminal... had a very bad experience and expensive lesson for this.. smoked my monoblock once due to short circuit at the amp's - terminal when installing the ground cable. [/QUOTE]
(WTS)TOMEI 3 POINT front Strut bar for Silvia S14/S15
RM300 nett ,very good condition.
call me if interested. 019-3828 979 Leo. thanks.
http://drift.com.my/forum/viewtopic.php?t=17160
Honda NSX Postponed Again !
The on-off saga of the launch of Honda’s all new supercar took another twist last week when CEO Takeo Fukui announced that Honda was putting...
WTA :Wiring about Pivot shift lamp
got 1 used pivot shift lamp from fren.. any 1 know how to install..
i saw it got 6 wires behind ./// 2 wire is for the light
balance 4 wires = red black white n oren..
any1 know how to connect???
thanks
Main Forums
Interests
ICE
