HKS 10W35 Super Racing Engine Oil
Timeattacker
Johor Bahru
HKS Super Racing 10W35 Engine Oil, Imported Oil.
Why HKS Oil:
HKS engine oils are developed with an idea of that oil is a tuning part to maximize performance of engine. The unique viscosity categorization will effect at molecular level on boundary lubrication. Optimized oil viscosity selection solves hydrodynamic lubrication. Air-tightness and friction are highly balanced.
Engine building specialist at HKS now offer 100% synthetic special blend oil.
Benefit of using HKS Engine Oil;
- 100% Synthetic Oil High Shear Stability;
- Able to penetrate piston oil line during engine operation to reduce friction thus allowing smooth engine movement;
- Seal up the gas leakage from combustion chamber to maintain good compression;
- Complete absorption and dissipation to cool the engine and prevent it from overheating;
- To eliminate combustion gas Unburned deposit that may affect the engine performance;
- Remove moisture content from during combustion that create rust and corrode the engine.
SUPER RACING 10W35 is Recommended for Stock Engines - Lightly & Modified Tuning in N/A & Turbo Applications. With a good Cold Weight of 10W this gives ample protection.35 Hot weight running at Average Oil temp of 90c becomes a 40 Weight.
- Recomended/Best to use for vehicles, which specified oil is W30,etc;
- Myvi ,4G63 RB20 RB25 RB26 CA18 SR20 3SGE 4AGE 2JZ 1JZ VQ35 VQ25 B16 B18 K20 K24 BP EJ20 EJ25,WRX EVO SKYLINE 180SX 200SX GTR TYPE R V-TECH STi GT4
Applicable for stock specified W30 Grade;
- Max Oil Temp 130Ž
- 100“ SYNTHETIC
- SM-CF equivalent
PM me for best price @ 016.964.5648
Thanks for viewing & 0-100 admins
