Main Forums
Car Talk
Car Modification
Higher compression vs Lower compression pistons
<blockquote data-quote="Waiora_ProTuner" data-source="post: 1064333788" data-attributes="member: 43825"><p>The total compression (dynamic) would be higher (so high), unless you're lowering the boost...</p><p></p><p>Static compression creates more heat..prone to detonation...air compress by compressor (as in turbo) would go through intercooler (or at least long enough route to be cooled slightly)...</p><p></p><p>For the same total compression, lower static compression would give better detonation elimination...but peakier torque curve (higher boost threshold)..higher static compression (low boost) would give better torque curve, but require more care for detonation..</p><p></p><p>But normally manufacturer just go for bigger engine low boost...or low static ratio and low boost..so no problem here...</p></blockquote><p></p>
[QUOTE="Waiora_ProTuner, post: 1064333788, member: 43825"] The total compression (dynamic) would be higher (so high), unless you're lowering the boost... Static compression creates more heat..prone to detonation...air compress by compressor (as in turbo) would go through intercooler (or at least long enough route to be cooled slightly)... For the same total compression, lower static compression would give better detonation elimination...but peakier torque curve (higher boost threshold)..higher static compression (low boost) would give better torque curve, but require more care for detonation.. But normally manufacturer just go for bigger engine low boost...or low static ratio and low boost..so no problem here... [/QUOTE]
Move DRYCELL battery behind
hi guys,
i think this thread has been discussed before, but i got few things to clarify before me do the DIY project.
sorry for creating a new thread. ;-)
some mention that the cables being used to pull from the...
apexi power fc for evo4-8..map!!
power fc for evo7and8,map..not air flow...comes with map sensor...fc commander...harness for evo 8 rm2300nego!!!!
please call me at 012-6077811....thanks!! ITEM SOLD...THANKS!!!
Fd3s Limited Edition Tail Lamp For Sale
A Set Of The Fd3s Limited Edition Tail Lamp For Sale....
Call Me Up For The Price....
Or Pm Me
Main Forums
Car Talk
Car Modification
