High Boost Civic D16 turbo combo package!
RE-aMeMiYa
NIPPON RACING TURBO PISTONS( MADE IN JAPAN)
SCAT FORGED 5394 H-BEAM CONNECTING RODS WITH ARP 2000 BOLTS (MADE IN USA)
NPR GAS NITRITE N-51 TREATED PERFORMANCE RINGS.
9310 CASE HARDENED WRIST PINS WITH UPGRADED CLIPS
THIS KIT WILL FIT
HONDA CIVIC D16A6 D16Z6 D16Y8 D16Y7 D16Y5 DOHC ZC SOHC ZC ENGINES AND ALL SOHC MOTOR FROM EG, EJ, EK SOHC NON VTEC OR VTEC ENGINES.
*For other models please feel free to ask.
THESE PISTONS ARE AVALABLE IN
STD (75mm BORE)
75.5mm (.020")
AND 76mm (.040")
THIS KIT HAS BEEN TESTED TO HOLD 350+ WHP WITH PROPER FUEL AND TUNING.
THESE PISTONS ARE DESIGNED FOR TURBO APPLICATIONS AS THEY WILL SIGNIFICANTLY LOWER YOUR COMPRESSION.
THE COMPRESSION RATIO IS APPROX 8.5:1 (DEPENDING ON YOUR HEAD GASKET THICKNESS)
THESE PISTONS CAN HOLD 18-22 (psi) = ( 1.3-1.5 bar) TURBO BOOST IN A PROPERLEY TUNED ENGINE.
THESE PISTONS COME WITH AN EXTRA LUBRICATION SLOT ON THE WRIST PIN FOR PIN LUBRACATION THAT IS FAR SUPERIOR TO THE LESS EXPENSIVE MADE IN TAWAIN UNITS.
THIS IS DONE TO PREVEN PIN DAMAGE UNDER EXTREME PRESSURE.
Don’t be fooled by cheap imitations.
If insterested please call me at 0126573809
