Car Brands
Car Manufacturers
Toyota
Help Need....on Local Ae101
<blockquote data-quote="trd_1420" data-source="post: 2309832" data-attributes="member: 22744"><p>bro ae76, i think the dashboard should fit. I drives a LE with Levin Svt and dasboard fitted in to my car. I did my car at sunway LSF auto. You can try him out.</p></blockquote><p></p>
[QUOTE="trd_1420, post: 2309832, member: 22744"] bro ae76, i think the dashboard should fit. I drives a LE with Levin Svt and dasboard fitted in to my car. I did my car at sunway LSF auto. You can try him out. [/QUOTE]
4g63t missfire.. help!!
hi all.... now i still troubleshooting my missfiring prob....
on idle = smooth
accelerate = smooth
boosting = smooth
misfire only at above 4000rpm while part throttle or maintain rpm... it happen at all gear...
revvin from 3k onwards felt heavy
im runnin on rb25det, everytime i rev past 3k rev, i felt da car is sluggish, n felt like combustion is stuffed...
any idea? wat plugs i shud use for stock engine stock boost stock setup?
when i take a corner...
b16a change b16b cam and valve spring with retainer problem
permalink
Need Help. currently my civic b16a change b16b cam and valve spring retainer problem.
Problem is when start car. need to press fuel for not...
Car Brands
Car Manufacturers
Toyota
