Car Brands
Car Manufacturers
Honda
Gear ratios.
<blockquote data-quote="shiroitenshi" data-source="post: 2548911" data-attributes="member: 27518"><p>Actually gear ratios quite easy to study.. </p><p></p><p>you want the car to pull the hardest and gain speed without dropping out of the powerband.</p><p></p><p>If you swap ratios, you make consession for the next gear you didn't swap.. it might be good, it might be bad.</p><p></p><p>If you have good torque, you just need the gears to fall in the same spot for each gear, so you can use full-throttle shift function. If not, you will only be able to use full throttle shift for certain gears.</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 2548911, member: 27518"] Actually gear ratios quite easy to study.. you want the car to pull the hardest and gain speed without dropping out of the powerband. If you swap ratios, you make consession for the next gear you didn't swap.. it might be good, it might be bad. If you have good torque, you just need the gears to fall in the same spot for each gear, so you can use full-throttle shift function. If not, you will only be able to use full throttle shift for certain gears. [/QUOTE]
Racetech "Rigid collars" / Chassis Alignment Kit
I'm what you'd call a
car enthusiast
. I'm knowledgeable enough to not be conned by dishonest shops and I am...
Buying A Skyline!
Hey, people.
First of all I would like to say hi and greetings to all Skyline fans and owners out there.
Secondly, I don't own a Skyline (YET!!!). I am thinking of getting one maybe somewhere after Chinese New Year...
TT session - 9 June 2006 - Pictures Uploaded
Dear Skyline's Owners,
It will be great to have Nissan Sportcar Owners to get together and get to know each other.
Time: 9pm - 11pm
Place: The usual...
Car Brands
Car Manufacturers
Honda
Gear ratios.
