Main Forums
Car Talk
Forced Induction & Engine Management
exhaust setup for gsr
<blockquote data-quote="ezwong2002" data-source="post: 100469" data-attributes="member: 2377"><p>of coz 4wd tank is always better.. coz the fuel pump also comes together. have to make sure it's working la.. coz when i transplant my car time.. my 4wd tank fuel pump got problem. If u are driving Wira/Putra 4wd can be optional.. but if satria strongly recommend 4wd tank.. coz installing the exhaust piping would be easier... some of the set-ups I've heard for Std or lightly modified GSR are as below</p><p></p><p>:-</p><p>1. Original Exhaust Manifold</p><p>2.5" Pipings and 2.5" Inlet Muffler</p><p></p><p>2. Original Exhaust Manifold</p><p>2.5"Piping - 3"Center Piping - 3" or 3.5" Inlet Muffler</p><p></p><p>3. Custom Exhaust Manifold ( Can fit External Wastegate )</p><p>3" all the way</p><p></p><p></p><p>FYI : I used the first option when I just finished my transplant.. den I upgrade to the second setup. Higher High-End Power. That is for sure.</p></blockquote><p></p>
[QUOTE="ezwong2002, post: 100469, member: 2377"] of coz 4wd tank is always better.. coz the fuel pump also comes together. have to make sure it's working la.. coz when i transplant my car time.. my 4wd tank fuel pump got problem. If u are driving Wira/Putra 4wd can be optional.. but if satria strongly recommend 4wd tank.. coz installing the exhaust piping would be easier... some of the set-ups I've heard for Std or lightly modified GSR are as below :- 1. Original Exhaust Manifold 2.5" Pipings and 2.5" Inlet Muffler 2. Original Exhaust Manifold 2.5"Piping - 3"Center Piping - 3" or 3.5" Inlet Muffler 3. Custom Exhaust Manifold ( Can fit External Wastegate ) 3" all the way FYI : I used the first option when I just finished my transplant.. den I upgrade to the second setup. Higher High-End Power. That is for sure. [/QUOTE]
Timing Belt Oil & Engine Leaking
Hi
Sifous
My ride is a
Proton Perdana 2001 V6 (A) clocking 125K Km now
Just discovered the Engine oil is leaking
An initial check shows the leak to be from the...
7/7: When all RX-7s come out to play - RE Club at Malacca
Malaysian rotary nuts pay respects to the auspicious 7/7, where RX-7s everywhere congregate while they share their wankel experience...
F1: Singapore GP Ticketing
The tickets for the most anticipated race of the year are already on sale with a total of 70,000 tickets made available in...
Main Forums
Car Talk
