Main Forums
Car Talk
Forced Induction & Engine Management
EP82 turbine help
<blockquote data-quote="HKS-GT2835R" data-source="post: 927523" data-attributes="member: 2710"><p>Originally, the CT9 that's bolted on to the EP82 engine has 2 boost modes, lo boost = 0.4bar, hi boost = 0.6 bar, but that's controlled electronically via a small solenoid found in front of the servo brake.</p><p>you wanna set the max boost via using either the famous 'tulang ikan' or wat?</p></blockquote><p></p>
[QUOTE="HKS-GT2835R, post: 927523, member: 2710"] Originally, the CT9 that's bolted on to the EP82 engine has 2 boost modes, lo boost = 0.4bar, hi boost = 0.6 bar, but that's controlled electronically via a small solenoid found in front of the servo brake. you wanna set the max boost via using either the famous 'tulang ikan' or wat? [/QUOTE]
Topless Porsche 991 let loose on Malaysian roads!
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/s720x720/559092_587573673330_283900550_2314296_367290369_n.jpg
Back in Feb 2012, we reported the...
Milanza HZ-1 ok or not??
Milanza HZ-1 tire .. come to share what the advantages and disadvantages???
this tyre made from korea..
how this tyre control in acceleration, cornering and braking under extreme conditions...
vertex altezza video clip
turn on ur speaker when playing the video clip....
http://www.megaupload.com/?d=TGF6U9UQ
Main Forums
Car Talk
EP82 turbine help
