Main Forums
Interests
Do-It-Yourself Garage
DIY Dicharge Cutting System (DCS)
<blockquote data-quote="SpeedWanker" data-source="post: 552607" data-attributes="member: 311"><p>guess wut Mr. Rung is saying has some truth to it.. ever noticed especially on smaller engines, the moment u switch on u're lights or high beam u're engine's rpm seems to drop? well i guess that the load he's trying to avoid, the load from the alternator when trying to keep u're batt fully charge..</p><p>so if only we could somehow stop the alternator temporarily from charging during our night drags and power all electricall equipments via the batt then we should theoritically gain some power, not much but maybe a slightly better trottle respond of the line..</p></blockquote><p></p>
[QUOTE="SpeedWanker, post: 552607, member: 311"] guess wut Mr. Rung is saying has some truth to it.. ever noticed especially on smaller engines, the moment u switch on u're lights or high beam u're engine's rpm seems to drop? well i guess that the load he's trying to avoid, the load from the alternator when trying to keep u're batt fully charge.. so if only we could somehow stop the alternator temporarily from charging during our night drags and power all electricall equipments via the batt then we should theoritically gain some power, not much but maybe a slightly better trottle respond of the line.. [/QUOTE]
Aventador storms across Californian desert for commercial w/video
https://www.zerotohundred.com/wp-content/uploads/2011/03/lambo.jpg
The Lamborghini Aventador is probably the sexiest thing with an engine currently on the surface of the planet, bar none. Therefore it needs a...
Ecu Pinout
Guys,
I'm looking for ecu pinout diagram for Satria 1.6. Anybody that have a copy of the diagram is appreciate to give me the link. tq
Air Filter Heat Shield DIY
This was something I did a while ago. I realised that the hot air from the radiator fan blows directly at the air filter and this will cause the air intake tempreature to be high. I had a hose that channels air from...
Main Forums
Interests
