Car Brands
Car Manufacturers
Honda
Check Engine Warning Lamp!!!
<blockquote data-quote="SAO 6418" data-source="post: 1130806" data-attributes="member: 14385"><p>i'm also experience the check light on my JDM D15B 3-stage vtec engine (swap into 2nd gen civic). after checking the code and it was the TPS (Trottle Position Senser) problem. </p><p></p><p>Firstly to check the code u need 2 find the socket which locate nearby ur ecu, find the blue color socket with only two wires (normally this socket will be stick together with another 3 wires socket which will be place in one rubber casing (green). Pull out the 2 wires (brown & black) socket and then use the jumper or wires to short circuit the socket (connection). after that turn the ignition key to on (not starting), then u'll see the check light blinking so from there u count the blinking light to determine the code. </p><p></p><p>But if too much problem then is quite difficuit to check the blinking sequence so it is better to clear all the code by disconnect the battery from the car then connect back again. All the error code in the ecu will be erase and now drive ur car whatever u want, once the check light turn on (after start the engine) then imediately check the code as mention above. For the blinking sequence, u need to refer to the honda ecu trouble code.</p></blockquote><p></p>
[QUOTE="SAO 6418, post: 1130806, member: 14385"] i'm also experience the check light on my JDM D15B 3-stage vtec engine (swap into 2nd gen civic). after checking the code and it was the TPS (Trottle Position Senser) problem. Firstly to check the code u need 2 find the socket which locate nearby ur ecu, find the blue color socket with only two wires (normally this socket will be stick together with another 3 wires socket which will be place in one rubber casing (green). Pull out the 2 wires (brown & black) socket and then use the jumper or wires to short circuit the socket (connection). after that turn the ignition key to on (not starting), then u'll see the check light blinking so from there u count the blinking light to determine the code. But if too much problem then is quite difficuit to check the blinking sequence so it is better to clear all the code by disconnect the battery from the car then connect back again. All the error code in the ecu will be erase and now drive ur car whatever u want, once the check light turn on (after start the engine) then imediately check the code as mention above. For the blinking sequence, u need to refer to the honda ecu trouble code. [/QUOTE]
Better air fuel ratio for torque?
Saw some of the website recommend for A/F
13.5:1 , Good for Torque ( 0-100 km/h)
12:5:1 , Good for HP ( top speed)
11.5:1 , Good for Torque ( 0-100 km/h)
I would wonder 13.5 is better or 11.5 is better for torque...
Pls help!!!!!!!
hi everybody,recently i brought an evolution 7.5 GTA from a malay gentlement from damansara,it's a black one shown in 'The Motortrader' recently. When i first drive the car,it seems ok n everything seems...
Sport Rim Spray
COSTING RM17
BLACK SPRAY TIN (RM5)
BALCK 2 TIN...LACQUOR 1 TIN....
Car Brands
Car Manufacturers
Honda
