Main Forums
Car Talk
Forced Induction & Engine Management
Anyone using Ultimate Emanage ?
<blockquote data-quote="renxun" data-source="post: 3768357" data-attributes="member: 33177"><p>rpm extension is not stable, timing in datalog not really accurate.some bugs... u need to really understand this thing b4 you can diy tuning. for example. coolant temp compensation the unit need to be in Farenheit instead of celcius else it will mess up, the injector map if using large injector you need to use the unit in ms instead of duty cycle as emu had a lil trouble wid pulling out fuel in duty cycle form. when your car had knock, the stock ecu will pull timing resulting in your datalog showing negative value. even at idle your timing will be in negative. need to off the car to reset it. a lot to mention la.... when you play wid it you will know la... but i went thru everything and found solution for all the trouble i faced</p></blockquote><p></p>
[QUOTE="renxun, post: 3768357, member: 33177"] rpm extension is not stable, timing in datalog not really accurate.some bugs... u need to really understand this thing b4 you can diy tuning. for example. coolant temp compensation the unit need to be in Farenheit instead of celcius else it will mess up, the injector map if using large injector you need to use the unit in ms instead of duty cycle as emu had a lil trouble wid pulling out fuel in duty cycle form. when your car had knock, the stock ecu will pull timing resulting in your datalog showing negative value. even at idle your timing will be in negative. need to off the car to reset it. a lot to mention la.... when you play wid it you will know la... but i went thru everything and found solution for all the trouble i faced [/QUOTE]
Cusco Type I rear lower bar
Has anyone fitted a Cusco Type I rear lower bar? If yes, can you post some pics?
Detuned
Guys,
can i actually detune a high performance car to a daily drive-able car?
for example, a heavyly modified skyline with over 500 hp... would it be possible that i detune it to about 300hp so that it's more fuel...
drooling... some toys for Altezza
I wish i am rich... :sad_smile:
http://www.greenline.jp/catalogue/bcpartlist.php?make=Toyota&carcode=SXE10&intake=NA#engine
Main Forums
Car Talk
