Car Brands
Car Manufacturers
Hyundai
The Hyundai Coupe Club
Aircon Maintenance
<blockquote data-quote="wwshyue" data-source="post: 2201781" data-attributes="member: 26840"><p>Hi guys,</p><p></p><p>Recently i have bad luck on my airconds, started since last year Nov/Dec....when i 1st change the valve on the cooling coil....cost me RM120...done at my relative's shop at my hometown...then after 2 months around CNY...change a nut on the "botol"....i dunno wat it is called....it is the "botol" with a small littel transparent viewing spot on it.....that 1 cost me around RM20...done at my relative's shop again...then las month....the aircond make problem again....i went to check again and discover 1 of the fan is not working(big 1)...later on found out the fius connecter is dirty and make the fan stop....so we suspected is the hot engine make the aircond fail....masuk gas and do some servicing(FOC @ my relative's shop)......las week.....it fails again.....so i went to 1 of the shop in klang and they found out is the cooling coil leaking (a big 1)...ask them to change for me a new 1....cost me RM320 for part and RM80 for the gas and labour......i dunno y the cooling coil so cheap compare to MR. Lee.....i heard the mechanic call the supplier said he wants the original cooling for coupe.....then when the supplier sent the cooling coil...i see it is denso brand(the broken 1 also denso Brand)...i am not sure whether it is an original or not.....but i don care la...since he said the thing got 1 year warranty....</p><p></p><p>just share with you guys some info on my recent bad luck...</p></blockquote><p></p>
[QUOTE="wwshyue, post: 2201781, member: 26840"] Hi guys, Recently i have bad luck on my airconds, started since last year Nov/Dec....when i 1st change the valve on the cooling coil....cost me RM120...done at my relative's shop at my hometown...then after 2 months around CNY...change a nut on the "botol"....i dunno wat it is called....it is the "botol" with a small littel transparent viewing spot on it.....that 1 cost me around RM20...done at my relative's shop again...then las month....the aircond make problem again....i went to check again and discover 1 of the fan is not working(big 1)...later on found out the fius connecter is dirty and make the fan stop....so we suspected is the hot engine make the aircond fail....masuk gas and do some servicing(FOC @ my relative's shop)......las week.....it fails again.....so i went to 1 of the shop in klang and they found out is the cooling coil leaking (a big 1)...ask them to change for me a new 1....cost me RM320 for part and RM80 for the gas and labour......i dunno y the cooling coil so cheap compare to MR. Lee.....i heard the mechanic call the supplier said he wants the original cooling for coupe.....then when the supplier sent the cooling coil...i see it is denso brand(the broken 1 also denso Brand)...i am not sure whether it is an original or not.....but i don care la...since he said the thing got 1 year warranty.... just share with you guys some info on my recent bad luck... [/QUOTE]
PROTON Says DRB-HICOM Not Selling Lotus!
PROTON has just reiterated that their new holding company - DRB-HICOM Bhd, will not be selling Lotus, which is a...
Japanrims.com.my
Anyone ever buy from them? Here's the link:
http://www.japanrims.com.my/contact.php
I am actually quite interested with one of the rims listed on their site, but I felt skeptical to bank in my cash. I am located at...
Looking for power fc
Looking for an apexi power fc ecu+commander.
Do let me know if there are any out there..
Car Brands
Car Manufacturers
Hyundai
Aircon Maintenance
