Main Forums
General Talk
Air or Nitrogen gas?
<blockquote data-quote="prodigy" data-source="post: 767383" data-attributes="member: 232"><p>Which is exactly my point. The one major advantage of nitro over air is the fact it doesn't expand as much as air. And as i mentioned earlier, if you're really into high end tuning, then your tire pressure matters. Just like Formula 1 whereby even if they release a couple psi, the drivers will feel extra traction thru the corners. But as we drive daily on the roads where we seldom exceed 140kmh and don't take corners at 80kmh, would you seriously feel any difference when the air inside the tires expand?</p><p></p><p>Anyway, i didn't actually mean the tyre will hardened up. Its taken out of the original context.</p></blockquote><p></p>
[QUOTE="prodigy, post: 767383, member: 232"] Which is exactly my point. The one major advantage of nitro over air is the fact it doesn't expand as much as air. And as i mentioned earlier, if you're really into high end tuning, then your tire pressure matters. Just like Formula 1 whereby even if they release a couple psi, the drivers will feel extra traction thru the corners. But as we drive daily on the roads where we seldom exceed 140kmh and don't take corners at 80kmh, would you seriously feel any difference when the air inside the tires expand? Anyway, i didn't actually mean the tyre will hardened up. Its taken out of the original context. [/QUOTE]
david tao
RB26DETT Oil Pumps advice needed.
Hey guys:wavey:,
I'm driving a R34 and as of last month my oil press is reading slightly below the norm. It's reading at less than...
i need info on parts, USDM Outlander->Airtrek
I am in the works of looking for a good candidate to swap a USDM Auto Outlander to a 2.4 Evo head 4g64/3T. The 03-04 models come in Automatic only but from what I can tell and have read, they are the same chassis as...
Ganador Titanium Muffler Tip
This is a "plug and play" item that will fit onto your existing muffler tip.
Lengh: 5.5 inch
Inner diameter: 3.8 inch
Price: RM 280.00
Remus 017 3666 666
Ivan 012 6690525
Main Forums
General Talk
