Car Brands
Car Manufacturers
Toyota
4AGZE cam question
<blockquote data-quote="1JZtezza" data-source="post: 3959719" data-attributes="member: 66560"><p>try varying your cam peak-4agze inlet 232deg should be 108deg ATDC;exhaust 232 deg should be</p><p>108deg BTDC but for 240deg (standard 4age peak Inlet is 111deg ATDC and Exhaust 111deg BTDC.Try simulate higher boost and minimize overlap.Saw the program but did not download it.</p><p>The 1JZ TT runs a smaller duration inlet cam than exhaust.</p></blockquote><p></p>
[QUOTE="1JZtezza, post: 3959719, member: 66560"] try varying your cam peak-4agze inlet 232deg should be 108deg ATDC;exhaust 232 deg should be 108deg BTDC but for 240deg (standard 4age peak Inlet is 111deg ATDC and Exhaust 111deg BTDC.Try simulate higher boost and minimize overlap.Saw the program but did not download it. The 1JZ TT runs a smaller duration inlet cam than exhaust. [/QUOTE]
New MD Now Helms Goodyear Malaysia!
A new Managing Director comes rolling in for Goodyear Malaysia and she is none other than Ivy...
Attention to Mitsubishi Lancer 2.0G owner
Hello everybody ,
I am from Nielsen, we are currently doing a survey to understand customer feedback toward Mitsubishi Lancer (Delivery date: July 2008 - June 2009). We would like to meet with you, just to collect...
ECU EVO 1/2/3 Stock.
Guys need a bit of help, is there any Major difference between these Three Stock ECU ?
Can These three Ecu be swap, like evo 3 ecu on evo 1engine and evo 1 ecu on evo 3 engine ? will it do any harm...what are the...
Car Brands
Car Manufacturers
Toyota
4AGZE cam question
